[Qgis-user] Debian jessie - QGIS 2.10.1 'Pisa' - can't find srs.db - reg.
Jaisen Nedumpala
jaisuvyas at gmail.com
Wed Oct 21 22:54:06 PDT 2015
Update:
Fixed it.
Manually placed the following file in path ( /usr/share/qgis/resources/ ):
https://github.com/qgis/QGIS/blob/master/resources/srs.db
But it is not a good solution. Need to be fixed in relevant packages itself.
Thank you.
2015-10-22 10:49 GMT+05:30 Jaisen Nedumpala <jaisuvyas at gmail.com>:
> Hai,
> Debian jessie - QGIS 2.10.1 'Pisa' - Can't find
> /usr/share/qgis/resources/qgis.db.
> It is a matter of urgent. Need help. After an upgrade, when tried to
> change CRS of a shapefile, it is found that no coordinate reference systems
> are listed there in the Coordinate Reference System selector dialogue box.
> Further investigation with log messages revealed that the file is not there
> in path.
> I have searched for the file to fix it temporarily by manually copying it,
> couldn't find it anywhere. Please help me..!
> Copy pasting the log messages here:
> General:
> 2015-10-22T10:34:35 0 QGIS starting...
> 2015-10-22T10:34:36 0 Python support ENABLED :-)
> 2015-10-22T10:34:40 0 Application state:
> QGIS_PREFIX_PATH env var:
> Prefix: /usr
> Plugin Path: /usr/lib/qgis/plugins
> Package Data Path: /usr/share/qgis
> Active Theme Name: default
> Active Theme Path: :/images/themes/default/
> Default Theme Path: :/images/themes/default/
> SVG Search Paths: /usr/share/qgis/svg/
> /home/jaisen/.qgis2//svg/
> User DB Path: /usr/share/qgis/resources/qgis.db
> 2015-10-22T10:34:40 0 QGIS Ready!
> Python warning:
> 2015-10-22T10:34:38 1
> warning:/home/jaisen/.qgis2/python/plugins/TileMapScaleLevels/tilemapscaleplugin.py:72:
> DeprecationWarning: QgsMapCanvas.mapRenderer() is deprecated
> self.projection = self.canvas.mapRenderer().destinationCrs()
> traceback: File "<string>", line 1, in <module>
> File "/usr/lib/python2.7/dist-packages/qgis/utils.py", line 228, in
> startPlugin
> plugins[packageName].initGui()
> Processing:
> 2015-10-22T10:34:39 2 Problem with SAGA installation: SAGA was not found
> or is not correctly installed
> CRS
> 2015-10-22T10:43:35 1 Could not open CRS database
> /usr/share/qgis/resources/srs.db
> Error(14): unable to open database file
> 2015-10-22T10:43:49 1 Could not open CRS database
> - ജയ്സെനോവ് നെടുമ്പാലോവിച്ച് പഹയനോവ്സ്കി -
> «´¨`·* . Jaisenov. *..´¨`»
> ( `v´ )
> `v´
( `v´ )
`v´
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151022/8c132cdd/attachment.html>
