[Qgis-user] SUMMIT elevation map from a DEM ( SRTM)
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Thu Oct 22 13:02:58 PDT 2015
Or you could try the LecoS landscape ecology plugin.... There is a max statistic there also.
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112 Fax: 514.381.4995
www.archeotec.ca
On Oct 22, 2015 05:05, "agustin_mac [via OSGeo.org]" <ml-node+s1560n5231911h2 at n6.nabble.com> wrote:
If you have a graticule, gridstatisticsforpolygons in processing will do the trick, if not “creategraticule” and then gridstatisticsforpolygons
Something like these commands in the processing commander but it can be done with the gui as well:
processing.runalg("saga:creategraticule",None,”xmin,xmax,ymin,ymax”,1000,1000,1,”/path/towhereyouwantosave/your_graticule")
processing.runalg("saga:gridstatisticsforpolygons”,"your_mdt.tif","/path/towhereyour_graticule_is",False,False,True,False,False,False,False,False,0,None)
On 22Oct, 2015, at 7:19 AM, Allan López < [hidden email] > wrote:
> I need to create a SUMMIT elevation map from a DEM ( SRTM). At every square km I need to extract : Lat, Long and MAXIMUM elevation ( within that square km) and so on for all the grid. Someone suggested topology-algebra but that is too much for me !. I will appreciate a "receipt" or any other practical suggestion for QGIS
> Allan López
> Qgis-user mailing list
> [hidden email]
> http://lists.osgeo.org/mailman/listinfo/qgis-user _______________________________________________
[hidden email]
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/SUMMIT-elevation-map-from-a-DEM-SRTM-tp5231827p5231911.html
To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
To unsubscribe from Quantum GIS - User, click here .
NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/SUMMIT-elevation-map-from-a-DEM-SRTM-tp5231827p5232051.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151022/551406f9/attachment.html>
