[Qgis-user] Warning: Different behavior of $length in Field Calculator in "real" fields and virtual fields
magerlin
MAP at ramboll.dk
Sun Oct 25 02:31:07 PDT 2015
Fighting with getting lengths measured in meters I found this:
In Field Calculator $length returns the length in meters if the project CRS
uses meters (and OTF is on), *but not if it is used in a virtual field* -
then you will get length in units of the layer CRS!
Regards Morten
Currently using Qgis 2.10.1 (OSGeo4),
Windows 7, 64bit
View this message in context: http://osgeo-org.1560.x6.nabble.com/Warning-Different-behavior-of-length-in-Field-Calculator-in-real-fields-and-virtual-fields-tp5232434.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
