[Qgis-user] Exporting doesn't show all features
    Chris House
    housec01 at gmail.com
    Mon Oct 26 19:13:07 PDT 2015
Thanks Nyall!
It does appear there are 2 issues going on.  First the background using
open layers.  Switching to quick map services solved the OSM not displaying
in the export.  However, the issue of the shapeburst fill not displaying is
something else entirely.  It simply does not export.  I am using 2.8.2 Wien
on Microsoft windows 7 64bit. I have a single vector layer polygon that
i've changed the style to inverted fill and shapeburst.  I'm going from
Black to transparent.  The end result is that vector layer does not export
from the main map or the inset map.  Thanks again for any help!
--Chris
On Mon, Oct 26, 2015 at 5:22 PM, Nyall Dawson <nyall.dawson at gmail.com>
wrote:
> On 27 October 2015 at 01:37, Chris House <housec01 at gmail.com> wrote:
> > Hi all,
> > I am in the final stages of a project that will put my map in ppt.  I am
> > having trouble getting this map out of print composer with all the
> features
> > correct.  I have a basemap that is a raster with some vector on top of
> that.
> > One of the vectors are symbolized as inverted shapeburst.  It does not
> show
> > up on the png or PDF export.  I also have an inset map with OSM as
> basemap
> > and that inverted shapeburst on top....neither the vector or the OSM
> layer
> > show up in exports.
> > I've set the composition to both rasterize and not..didn't make a
> > difference.
> > I've locked all layers and layers styles, and set each to cache...
> > Am I missing something?  This is really important and fast deadline.
> Are you using the OpenLayers plugin for your basemaps? If so, don't.
> Use "Quick Map Services" instead.
> Nyall
> > Please help!!
> > Thanks
> > --Chris
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151026/300a8e8f/attachment.html>
