[Qgis-user] QGIS 2.12 unmet dependencies in Ubuntu
Martin Pescador
martin.pescador at inventati.org
Wed Oct 28 02:11:56 PDT 2015
Hello
I am trying to install QGIS 2.12 on Ubuntu 15.10. I have uninstalled a
previous version of Ubuntu and followed the instructions at
http://qgis.org/en/site/forusers/alldownloads.html#debian-ubuntu (i.e. I
have added the repository for the release with ubuntugis dependencies
and have added the two required debs to /etc/apt/sources.list
Following 'sudo apt-get install qgis python-qgis qgis-plugin-grass' the
message is
'Package qgis-plugin-grass is not available, but is referred to by
another package. This may mean that the package is missing, has been
obsoleted, or is only available from another source.'
Then trying with only 'sudo apt-get install qgis python-qgis' the
following is output:
Reading package lists... Done
Building dependency tree
Reading state information... Done
python-qgis is already the newest version.
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies.
qgis : Depends: libgdal1i (>= 1.8.0) but it is not going to be installed
Depends: libgeos-c1v5 (>= 3.4.2) but it is not going to be
installed
Depends: libqgis-analysis2.8.3 (>= 2.0.1) but it is not going
to be installed
Depends: libqgis-core2.8.3 (>= 2.8.3) but it is not going to be
installed
Depends: libqgis-gui2.8.3 (>= 2.8.1) but it is not going to be
installed
Depends: libqgis-networkanalysis2.8.3 (>= 2.0.1) but it is not
Depends: libspatialite7 (>= 2.4.0) but it is not going to be
installed
Depends: python-qgis (= 2.8.3+dfsg-1) but 1:2.10.1+20trusty is
to be installed
Depends: qgis-providers (= 2.8.3+dfsg-1) but it is not going to
be installed
Recommends: qgis-plugin-globe but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
If anybody could advise, I would be grateful.
Thanks, Martin
