[Qgis-user] QGIS 2.12 unmet dependencies in Ubuntu
César Augusto Ramírez Franco
caesarivs at gmail.com
Wed Oct 28 09:04:41 PDT 2015
Hello Martin,
According to the documentation available on the link you provided, the
Ubuntu versions which have ubuntugis dependencies available for QGIS are
only the LTS releases (i.e. 12.04 and 14.04), since you are on a non-LTS
release of Ubuntu (15.10) you should use the 'release' branch of qgis.
Your qgis entry on apt sources.list should look like this:
deb http://qgis.org/debian wily main # For QGIS 2.12
or
deb http://qgis.org/debian-ltr wily main # For QGIS 2.8
Greetings
2015-10-28 4:11 GMT-05:00 Martin Pescador <martin.pescador at inventati.org>:
> Hello
> I am trying to install QGIS 2.12 on Ubuntu 15.10. I have uninstalled a
> previous version of Ubuntu and followed the instructions at
> http://qgis.org/en/site/forusers/alldownloads.html#debian-ubuntu (i.e. I
> have added the repository for the release with ubuntugis dependencies and
> have added the two required debs to /etc/apt/sources.list
> Following 'sudo apt-get install qgis python-qgis qgis-plugin-grass' the
> message is
> 'Package qgis-plugin-grass is not available, but is referred to by another
> package. This may mean that the package is missing, has been obsoleted, or
> is only available from another source.'
> Then trying with only 'sudo apt-get install qgis python-qgis' the
> following is output:
> Reading package lists... Done
> Building dependency tree
> Reading state information... Done
> python-qgis is already the newest version.
> Some packages could not be installed. This may mean that you have
> requested an impossible situation or if you are using the unstable
> distribution that some required packages have not yet been created
> or been moved out of Incoming.
> The following information may help to resolve the situation:
> The following packages have unmet dependencies.
> qgis : Depends: libgdal1i (>= 1.8.0) but it is not going to be installed
> Depends: libgeos-c1v5 (>= 3.4.2) but it is not going to be
> installed
> Depends: libqgis-analysis2.8.3 (>= 2.0.1) but it is not going to
> be installed
> Depends: libqgis-core2.8.3 (>= 2.8.3) but it is not going to be
> installed
> Depends: libqgis-gui2.8.3 (>= 2.8.1) but it is not going to be
> installed
> Depends: libqgis-networkanalysis2.8.3 (>= 2.0.1) but it is not
> Depends: libspatialite7 (>= 2.4.0) but it is not going to be
> installed
> Depends: python-qgis (= 2.8.3+dfsg-1) but 1:2.10.1+20trusty is to
> be installed
> Depends: qgis-providers (= 2.8.3+dfsg-1) but it is not going to be
> installed
> Recommends: qgis-plugin-globe but it is not going to be installed
> E: Unable to correct problems, you have held broken packages.
> If anybody could advise, I would be grateful.
> Thanks, Martin
> Qgis-user mailing list
*César Augusto Ramírez Franco*
Laboratorio de Sistemas Complejos Naturales
Escuela de Geociencias - Facultad de Ciencias
Universidad Nacional de Colombia - Sede Medellín
Teléfono: (57-4) 430 9369 - 300 459 6085
http://labscn-unalmed.github.io/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151028/57c93c9b/attachment.html>
