[Qgis-user] QGIS 2.8.2 GPS Tools and Garmin USB Connection
Markus Weidenbach
landconsult at freenet.de
Fri Oct 30 03:09:08 PDT 2015
Hi Antonio,
I have the same problem with the same GPS device (Garmin GPSMap 76CSx)
connected via USB cable to my Win 7 and QGIS 2.8: QGIS does not
recognize the Garmin device.
The USB driver is updated from the Garmin webpage and the connection
works to transfer data to the SD Card of Garmin using the windows
explorer ....
Did you meanwhile find any solution?
Regards,
Markus
Dr. Markus Weidenbach
*landConsult.de*
Geographical Information Management
and Environmental Planning
D-77815 Bühl
Germany
e.mail see: http://landConsult.de
Am 10.07.2015 um 15:45 schrieb Antonio Di Marco:
> Hi Lene thanks for your reply, the problem is not to open the GPX but
> is to download data with GPS Tools plug-in to directly show waypoints
> an the map.
> It seems that GPS Tools doesn't recognize my garmin76Csx and so the
> download fails.
> Il 10/07/2015 14.35, Lene Fischer ha scritto:
>> Hi Antonio,
>> You can open a GPX- file as any other vector file. Just remember to
>> choose the extension .GPX
>> The plugin is not needed to open.
>> Regards
>> *Lene Fischer*
>> Associate Professor
>> *Department of Geosciences and Natural Resource Management*
>> University of Copenhagen
>> MOB +45 40115084
>> lfi at ign.ku.dk <mailto:lfi at ign.ku.dk>
>> cid:image001.gif at 01D03029.2F3EC6A0
>> *Fra:*qgis-user-bounces at lists.osgeo.org
>> [mailto:qgis-user-bounces at lists.osgeo.org] *På vegne af *Antonio Di Marco
>> *Sendt:* 9. juli 2015 16:35
>> *Til:* qgis-user at lists.osgeo.org
>> *Emne:* [Qgis-user] QGIS 2.8.2 GPS Tools and Garmin USB Connection
>> In QGIS 2.8.2 I couldn't download my Garmin GPS waypoints through
>> Vector -- GPS Tools menu under an USB connection.
>> The device has this Command line under "Waypoint download":
>> %babel -w -i garmin -o gpx "%in" "%out"
>> I tried also this line: gpsbabel -w -i garmin -o gpx "%in" "%out"
>> In both cases I get this message:
>> *Layer is not valid: *The layer xxxx.gpx?type=waypoint is not a valid
>> layer and can not be added to the map
>> I need an usb connection not a serial one via COM1
>> To verify that was not a driver trouble or something else I tried to
>> gat the waypoints via GPSBABEL and everything is ok
>> Any answer will be very much appreciated
>> Antonio Di Marco
>> ARPAT (Agenzia Regionale per la Protezione Ambientale della Toscana)
>> Direzione tecnica - Settore SIRA (Sistema Informativo Regionale Ambientale)
>> Via N. Porpora, 22
>> 50144 Firenze
>> Tel.: +39-055-3206416 Fax: +39-055-3206324
>> email:antonio.dimarco at arpat.toscana.it <mailto:antonio.dimarco at arpat.toscana.it>
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151030/e1ead279/attachment.html>
Name: not available
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20151030/e1ead279/attachment.gif>
