[Qgis-user] QGIS 2.10.1 adding PostGIS Views
Leknín Řepánek
godzilalalala at gmail.com
Tue Sep 1 08:31:32 PDT 2015
Workaround about primary key in view, i had use sever times is using
window function "row_number() over()". It works in views and in query
from database manager.
Je;
On Tue, Sep 01, 2015 at 04:09:49PM +0200, Sandro Santilli wrote:
> On Tue, Sep 01, 2015 at 02:37:22PM +0200, Jürgen E. Fischer wrote:
> > Hi Sandro,
> > On Tue, 01. Sep 2015 at 13:48:33 +0200, Sandro Santilli wrote:
> > > I agree with Luca this should have been better not backported to 2.8.3.
> > > Only proper bugs should be backported, and this was a (debatable)
> > > GUI enhancement, as far as I can tell.
> > We intend to only backport fixes and not bugs. ;)
> > You were always supposed to select the key column - preselecting the first
> > column was the bug (also debatable). And #11317 is a ticket that demonstrates
> > there were unaware users.
> Reading #11317 I looks to me that the reported bug was about
> "Add PostGIS Layer" not giving the user full detail of why a
> layer could not be loaded: "is an invalid layer - not loaded".
> In this I agree with Aren here: http://hub.qgis.org/issues/11317#note-6
> > That the first column often happens to be the primary key and and the combobox
> > is not lexically sorted is somewhat pure luck - and unless you avoid having the
> > key verified (using "use estimated metadata"), keeping a wrongly select
> > column will make the layer to insert invalid.
> I agree that the reported regression was based on the false expectation
> that QGIS would pick a primary key automatically, but in the
> (unlikely?) case a user was aware of that and properly coded the view
> to ensure primary key was first (or only) numeric the change was
> indeed a degradation of the experience.
> > But I agree that the tooltip that you get on disabled lines (not only for the
> > key selection, but also geometry type and srid) might not be visible enough
> > (but that IMHO would be just a GUI enhancement).
> There should maybe be another rule about LTS backports being:
> debatable fixes/enhancement need to be debated more on list ?
> --strk;
> Qgis-user mailing list
