[Qgis-user] QGIS 2.10.1 adding PostGIS Views
Matthias Kuhn
matthias at opengis.ch
Tue Sep 1 10:54:13 PDT 2015
PS: I'm sure a pull request for compound primary keys will gladly be
merged :-)
On 09/01/2015 07:15 PM, James Keener wrote:
> I don't disagree that it's a bad practice. However, is qgis a tool
> that you work with or around? Do we want to say "your data must have X
> as part of its schema or qgis can't use it" or will qgis make the best
> it can with poor data. Honestly, being loudly opinionated is a valid
> option if the developers feel it doesn't decrease the user experience
> drastically.
> I'd also like to point out that the primary key need not be a single
> field. For instance (state_fips, county_fips) could be a valid key for
> county-based metrics. Going back to the previous question I posed, do
> we want to tell users to conform to a single-field primary key or will
> qgis accept valid schema designs. Again, it comes down to dev time vs
> the cost to the user experience.
> Jim
> On September 1, 2015 12:42:56 PM EDT, "Leknín Řepánek"
> <godzilalalala at gmail.com> wrote:
> Situation with a view without unique (and indexed) key is bad database
> model, or bad query. Using window function is unefficient, but i can't
> find another way to make unique column on query with duplicities in
> records. In query without duplicities is possible to use oid (but this
> needs tables with oids), or ctid (but ctid is slow).
> Sorting in row_number can be defined in (ORDER BY ...). But is
> unefficient (as you say). But works well for display smaller parts of
> data (thousands of features).
> Materialized view can be indexed. But this is about use case and it isnt
> a "pretty solution".
> Je;
> On Tue, Sep 01, 2015 at 11:36:53AM -0400, James Keener wrote:
> Please stop saying this. It's fine for certain situations, but
> it is not a permanently unique identifier for a row. It may
> change when the underlying table is altered. Sure, it's unique
> if you read the results and keep them in memory and never talk
> about it again, but qgis does that on its own already.
> Moreover querying on it is extremely inefficient. Querying
> against it forces a sequence scan on the table. Depending on
> the table and version, it could also try to materialize the
> view fully in memory before doing the scan. Jim On September
> 1, 2015 11:31:32 AM EDT, "Leknín Řepánek"
> <godzilalalala at gmail.com> wrote: Workaround about primary key
> in view, i had use sever times is using window function
> "row_number() over()". It works in views and in query from
> database manager. Je; On Tue, Sep 01, 2015 at 04:09:49PM
> +0200, Sandro Santilli wrote: On Tue, Sep 01, 2015 at
> 02:37:22PM +0200, Jürgen E. Fischer wrote: Hi Sandro, On Tue,
> 01. Sep 2015 at 13:48:33 +0200, Sandro Santilli wrote: I agree
> with Luca this should have been better not backported to
> 2.8.3. Only proper bugs should be backported, and this was a
> (debatable) GUI enhancement, as far as I can tell. We intend
> to only backport fixes and not bugs. ;) You were always
> supposed to select the key column - preselecting the first
> column was the bug (also debatable). And #11317 is a ticket
> that demonstrates there were unaware users. Reading #11317 I
> looks to me that the reported bug was about "Add PostGIS
> Layer" not giving the user full detail of why a layer could
> not be loaded: "is an invalid layer - not loaded". In this I
> agree with Aren here: http://hub.qgis.org/issues/11317#note-6
> That the first column often happens to be the primary key and
> and the combobox is not lexically sorted is somewhat pure luck
> - and unless you avoid having the key verified (using "use
> estimated metadata"), keeping a wrongly select column will
> make the layer to insert invalid. I agree that the reported
> regression was based on the false expectation that QGIS would
> pick a primary key automatically, but in the (unlikely?) case
> a user was aware of that and properly coded the view to ensure
> primary key was first (or only) numeric the change was indeed
> a degradation of the experience. But I agree that the tooltip
> that you get on disabled lines (not only for the key
> selection, but also geometry type and srid) might not be
> visible enough (but that IMHO would be just a GUI
> enhancement). There should maybe be another rule about LTS
> backports being: debatable fixes/enhancement need to be
> debated more on list ? --strk;
> Qgis-user mailing list Qgis-user at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-user -- Sent from
> my Android device with K-9 Mail. Please excuse my brevity.
> Sent from my Android device with K-9 Mail. Please excuse my brevity.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150901/af6088ed/attachment.html>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150901/af6088ed/attachment.sig>
