[Qgis-user] Problem with shapefile - Qgis Crashes during saving
Piotr Kania
p.kania at op.pl
Thu Sep 3 23:08:33 PDT 2015
Hi - it's true - in Qgis 2.10.1 it doesn't work, but when I add that shp
to Kosmo I see all features and I can edit that point shapefile. In
Kosmo I saved your layer once again, than I took prj file (EPSG 2272)
from spatialreference.org and add it to second layer as
"second_layer.prj" - I had 4 new files - "second_layer.shp, s....shx,
...dbf and s...prj.
When I add that "second_layer.shp" to Qgis it works ok - I see all
fetures and I can make edits.
W dniu 2015-09-03 o 19:48, boesiii pisze:
> Hello,
> I was trying to edit a shapefile and when I tried to save the shapefile,
> Qgis crashed on me. The original shapefile is linked below. When I add the
> shapefile to Qgis I can only see some features but when I try and pan/zoom
> around, the features disappear.
> What could be wrong?
> https://drive.google.com/file/d/0B1n1ENVCjkaANDVMZktkSXRXb2c/view?usp=sharing
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Problem-with-shapefile-Qgis-Crashes-during-saving-tp5222547.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
