[Qgis-user] Problem with shapefile - Qgis Crashes during saving
Andre Joost andre+joost at nurfuerspam.de
Fri Sep 4 07:53:11 PDT 2015
Am 04.09.2015 um 08:08 schrieb Piotr Kania:
> Hi - it's true - in Qgis 2.10.1 it doesn't work, but when I add that shp
> to Kosmo I see all features and I can edit that point shapefile. In
> Kosmo I saved your layer once again, than I took prj file (EPSG 2272)
> from spatialreference.org and add it to second layer as
> "second_layer.prj" - I had 4 new files - "second_layer.shp, s....shx,
> ...dbf and s...prj.
> When I add that "second_layer.shp" to Qgis it works ok - I see all
> fetures and I can make edits.
Alternatively, you can use the spatialite_gui to add all 1280 features
into a spatialite database. All GDAL based tools only add 7 features.
Maybe the shx file is broken.
HTH,
André Joost
