[Qgis-user] QGIS 2.10.1 adding PostGIS Views
James Keener
jim at jimkeener.com
Fri Sep 4 05:31:39 PDT 2015
Sorry for the double email. Also, I wonder how much we could extract
from EXPLAIN SELECT * FROM view; (alternatively EXPLAIN SELECT * FROM
view WHERE field1 = 1;) and if we could tease information out of that.
This all seems more complicated than it needs to be though.
Jim
On 09/04/2015 02:42 AM, Andrea Peri wrote:
> Ho,
> How do qgis to analyze the table to retrieve the unique?
> A loop on every record or a SQL to count distinct ?
> A.
> Il 04/set/2015 08:01, "Bernhard Ströbl" <bernhard.stroebl at jena.de
> <mailto:bernhard.stroebl at jena.de>> ha scritto:
> Am 03.09.2015 um 23:41 schrieb Sandro Santilli:
> On Wed, Sep 02, 2015 at 08:48:34AM +0200, Bernhard Ströbl wrote:
> Am 01.09.2015 um 17:49 schrieb Matthias Kuhn:
> 2. If there are tables without a PK open a second modal
> dialog with an
> explanation of the problem and offer to select a pk from
> a combobox.
> I hope you mean "relation" not table, a table should always
> have a
> PK.
> It's not mandatory for a table to have a PK.
> I guess by "tables without a PK" he means table for which no PRIMARY
> KEY constraint is explicitly defined (should an UNIQUE key be
> considered equally valid?).
> It is not mandatory, of course, that's why I wrote "should", but
> IMHO it is very bad database design to not define one.
> There might be several UNIQUE constraints on one table but there can
> be only one PK constraint. So in case of only a UINIQUE constraint
> the table would be handled as any other without PK constraint (or
> QGIS needs to analyse how many fields have a UNIQUE constraint).
> Bernhard
> __________ Information from ESET Mail Security, version of virus
> signature database 12200 (20150904) __________
> The message was checked by ESET Mail Security.
> http://www.eset.com
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
