[Qgis-user] QGIS: Print Composer shifts polygon layer in exported image
Tobias Preuss tobias.preuss+osgeo at googlemail.com
Sun Sep 6 04:47:26 PDT 2015
Hello.
I am using QGIS 2.10.1-Pisa on Ubuntu 14.04.
I am trying to export a PNG from print composer which renders a
polygon on top of a OpenStreetMap layer.
The preview of the image looks fine in print composer (see
QGIS-Print-Composer.png).
However, the exported PNG file shows the polygon shifted in a random
direction (see QGIS-PNG-exported.png).
I am able to reproduce this behavior also with different files and on
a different computer running QGIS 2.10.1-Pisa on Ubuntu 14.10.
The same happens when I export the composition as a PDF file.
For the example I used the following file:
https://raw.githubusercontent.com/unitedstates/districts/gh-pages/states/AL/shape.geojson
Can someone please confirm? I will open a bug report then if there is none.
Cheers, Tobias
___
QGIS-Print-Composer.png -> http://pasteboard.co/r6MYeBu.png
QGIS-PNG-exported.png -> http://pasteboard.co/r6RAZ2I.png
