[Qgis-user] QGIS: Print Composer shifts polygon layer in exported image
Nyall Dawson nyall.dawson at gmail.com
Sun Sep 6 04:58:27 PDT 2015
On 6 Sep 2015 9:48 pm, "Tobias Preuss" <tobias.preuss+osgeo at googlemail.com>
wrote:
> Hello.
> I am using QGIS 2.10.1-Pisa on Ubuntu 14.04.
> I am trying to export a PNG from print composer which renders a
> polygon on top of a OpenStreetMap layer.
> The preview of the image looks fine in print composer (see
> QGIS-Print-Composer.png).
> However, the exported PNG file shows the polygon shifted in a random
> direction (see QGIS-PNG-exported.png).
> I am able to reproduce this behavior also with different files and on
> a different computer running QGIS 2.10.1-Pisa on Ubuntu 14.10.
> The same happens when I export the composition as a PDF file.
> For the example I used the following file:
https://raw.githubusercontent.com/unitedstates/districts/gh-pages/states/AL/shape.geojson
> Can someone please confirm? I will open a bug report then if there is
none.
It's a well known bug in the open layers plugin. There's a couple of
workarounds like making sure your map totally fills the composer page, but
otherwise no real solutions yet.
Nyall
> Cheers, Tobias
> ___
> QGIS-Print-Composer.png -> http://pasteboard.co/r6MYeBu.png
> QGIS-PNG-exported.png -> http://pasteboard.co/r6RAZ2I.png
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150906/ce88c9a7/attachment.html>
