[Qgis-user] QGIS: Print Composer shifts polygon layer in exported image
Bernd Vogelgesang
bernd.vogelgesang at gmx.de
Sun Sep 6 05:11:28 PDT 2015
when the source of the problem is really the Open Layers Plugin, then
maybe try the QuickMapServices plugin instead.
Cheers
Bernd
Am 06.09.2015, 13:58 Uhr, schrieb Nyall Dawson <nyall.dawson at gmail.com>:
> On 6 Sep 2015 9:48 pm, "Tobias Preuss"
> <tobias.preuss+osgeo at googlemail.com> wrote:
>> Hello.
>> I am using QGIS 2.10.1-Pisa on Ubuntu 14.04.
>> I am trying to export a PNG from print composer which renders a
>> polygon on top of a OpenStreetMap layer.
>> The preview of the image looks fine in print composer (see
>> QGIS-Print-Composer.png).
>> However, the exported PNG file shows the polygon shifted in a random
>> direction (see QGIS-PNG-exported.png).
>> I am able to reproduce this behavior also with different files and on
>> a different computer running QGIS 2.10.1-Pisa on Ubuntu 14.10.
>> The same happens when I export the composition as a PDF file.
>> For the example I used the following file:
>> https://raw.githubusercontent.com/unitedstates/districts/gh-pages/states/AL/shape.geojson
>> Can someone please confirm? I will open a bug report then if there is
>> none.
> It's a well known bug in the open layers plugin. There's a couple of
> workarounds like making sure your map totally fills the >composer page,
> but otherwise no real solutions yet.
> Nyall
>> Cheers, Tobias
>> ___
>> QGIS-Print-Composer.png -> http://pasteboard.co/r6MYeBu.png
>> QGIS-PNG-exported.png -> http://pasteboard.co/r6RAZ2I.png
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
Bernd Vogelgesang
Siedlerstraße 2
91083 Baiersdorf/Igelsdorf
Tel: 09133-825374
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150906/14e0b48b/attachment.html>
