[Qgis-user] garmin file (gdb)
Andre Joost
andre+joost at nurfuerspam.de
Mon Sep 7 08:06:50 PDT 2015
Am 07.09.2015 um 12:39 schrieb Magi Franquesa:
> Hello,
> I’m trying to open a garmin file (.gdb) in the newest version of qgis
> (2.10.1 Pisa) and I can’t open it as always I do.
> I’ve installed again the version 2.8.1 and the file opens correctly
> (To open the .gdb file simply use add vectorial layer button) .
Just to clarify:
QGIS is able to load ESRI file geodatabases with .gdb file extension.
The way to open them is described in
http://gis.stackexchange.com/questions/26285/file-geodatabase-gdb-support-in-qgis
The files that are used by Garmin with the same .gdb ending have nothing
to do with those ESRI files. You can batch convert them using gpsbabel
as described in
http://gis.stackexchange.com/questions/18405/how-to-batch-convert-garmin-gdb-to-gpx
HTH,
André Joost
