[Qgis-user] Fwd: problems with the style of simple markers in pointlayers in QGIS 2.10 (Pisa)
Richard Duivenvoorde rdmailings at duif.net
Wed Sep 9 02:44:11 PDT 2015
Hi Marcel,
haven't seen this with my QGIS here (but I'm on Debian).
Is it possible it has something to do with the changed project file
syntax? Are you using older project files?
Is this issue also apparent when you start a fresh project?
If so: please create an reproducable use case and add an issue in the
issue list: see:
http://qgis.org/en/site/getinvolved/development/index.html#bugs-features-and-issues
(we are short in mac testers :-) )
Regards,
On 09-09-15 11:30, Marcel Stadelmann wrote:
> Hello,
> I tried now also with QGIS 2.8.3 and the behaviour is like in QGIS 2.6,
> which is good. I guess 2.10.1 has a bug regarding the style of simple
> markers in pointlayers.
> Thank you
> Marcel
> Anfang der weitergeleiteten Nachricht:
>> *Von: *Marcel Stadelmann <marcel.stadelmann at gmx.net
>> <mailto:marcel.stadelmann at gmx.net>>
>> *Betreff: **problems with the style of simple markers in pointlayers
>> in QGIS 2.10 (Pisa)*
>> *Datum: *9. September 2015 00:23:37 MESZ
>> *An: *"qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org>"
>> <qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org>>
>> Hello,
>> After an upgrade from QGIS 2.6 to 2.10 the styles of simple markers in
>> pointlayers can't be changed anymore. So I can't change anymore for
>> example the frame color of a point symbol. It appears just a text:
>> "Dieser Layer hat keine änderbaren Eigenschaften" (in english
>> something like: This Layer has no changeable characteristics). In QGIS
>> 2.6 the same project works well.
>> Is this intended or a bug?
>> I use the distribution from KyngChaos on OSX 10.8.5
>> Thank you
>> Marcel
> Qgis-user mailing list
