[Qgis-user] R: Re : [Qgis-developer] view only current feature inatlas maps
    Enrico Ferreguti
    enricofer at gmail.com
    Fri Sep 11 06:02:14 PDT 2015
I agree with Michaël. I do not mean to modify styles from composer. Checking the option in composer should not influence map styles. It should only control feature visibility on atlas map item.
Enrico.
Da: kimaidou
Inviato: venerdì 11 settembre 2015 14:04
A: Junior
Cc: Enrico Ferreguti;qgis-developer;qgis-user at lists.osgeo.org
Oggetto: Re: [Qgis-user] Re : [Qgis-developer] view only current feature inatlas maps
Another proposal : in the gui for rule base rendering, we could add a new column in the rules tables, name "Activate only for atlas", which will allow the user to toggle each rule. If the checkbox is checked, the rule is used only in atlas.
This way the user can tune more easily, in the context of QGIS vector layer properties.
I do not like having checkbox in the composer, since the composer is not always opened and visible.
Michaël
2015-09-11 12:16 GMT+02:00 Junior <delazj at gmail.com>:
i don't know if there is a work around but a big +1 for your UI proposal.
Envoyé depuis mon HTC
----- Reply message -----
De : "Enrico Ferreguti" <enricofer at gmail.com>
Pour : "qgis-developer" <qgis-developer at lists.osgeo.org>, "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
Objet : [Qgis-developer] view only current feature in atlas maps
Date : ven., sept. 11, 2015 10:49
Hi list,
when I need to isolate the current atlas feature in map views I currently enable the rule based feature style and I set the rule to "$atlasfeatureid = $id" following this tutorial: http://nathanw.net/2013/12/02/waiting-for-qgis-2-2-highlighting-current-atlas-feature/
I'm wondering if there is an easier method, accessible for the common gis user, to do this avoiding expressions and complex styling methods, and if it's possible to control this behaviour directly from "controlled by altas" slot in map item properties tab as from the attached sample image.
Regards
Enrico Ferreguti
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150911/ce1f145e/attachment.html>
