[Qgis-user] Re : [Qgis-developer] view only current feature in atlas maps
kimaidou
kimaidou at gmail.com
Fri Sep 11 05:04:25 PDT 2015
Another proposal : in the gui for rule base rendering, we could add a new
column in the rules tables, name "Activate only for atlas", which will
allow the user to toggle each rule. If the checkbox is checked, the rule is
used only in atlas.
This way the user can tune more easily, in the context of QGIS vector layer
properties.
I do not like having checkbox in the composer, since the composer is not
always opened and visible.
Michaël
2015-09-11 12:16 GMT+02:00 Junior <delazj at gmail.com>:
> Hi,
> i don't know if there is a work around but a big +1 for your UI proposal.
> Envoyé depuis mon HTC
> ----- Reply message -----
> De : "Enrico Ferreguti" <enricofer at gmail.com>
> Pour : "qgis-developer" <qgis-developer at lists.osgeo.org>, "
> qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
> Objet : [Qgis-developer] view only current feature in atlas maps
> Date : ven., sept. 11, 2015 10:49
> Hi list,
> when I need to isolate the current atlas feature in map views I currently
> enable the rule based feature style and I set the rule to "$atlasfeatureid
> = $id" following this tutorial:
> http://nathanw.net/2013/12/02/waiting-for-qgis-2-2-highlighting-current-atlas-feature/
> I'm wondering if there is an easier method, accessible for the common gis
> user, to do this avoiding expressions and complex styling methods, and if
> it's possible to control this behaviour directly from "controlled by altas"
> slot in map item properties tab as from the attached sample image.
> Regards
> Enrico Ferreguti
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150911/aea316ae/attachment.html>
