[Qgis-user] Re : [Qgis-developer] view only current feature in atlas maps
Junior delazj at gmail.com
Fri Sep 11 03:16:43 PDT 2015
i don't know if there is a work around but a big +1 for your UI proposal.
Envoyé depuis mon HTC
----- Reply message -----
De : "Enrico Ferreguti" <enricofer at gmail.com>
Pour : "qgis-developer" <qgis-developer at lists.osgeo.org>, "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
Objet : [Qgis-developer] view only current feature in atlas maps
Date : ven., sept. 11, 2015 10:49
Hi list,
when I need to isolate the current atlas feature in map views I currently enable the rule based feature style and I set the rule to "$atlasfeatureid = $id" following this tutorial: http://nathanw.net/2013/12/02/waiting-for-qgis-2-2-highlighting-current-atlas-feature/
I'm wondering if there is an easier method, accessible for the common gis user, to do this avoiding expressions and complex styling methods, and if it's possible to control this behaviour directly from "controlled by altas" slot in map item properties tab as from the attached sample image.
Regards
Enrico Ferreguti
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150911/8fb5edba/attachment.html>
