[Qgis-user] Action "open"  to open a pdf-File
    Peter Schürch
    p.schuerch at meierpartner.ch
    Mon Sep 14 01:02:55 PDT 2015
QGIS 2.8.1-Wien / Windows 8 / MSSQL-Spatial
Hi List
I want to open a PDF-File from the QGIS-Object-Attribute Window (which pops up when I click with the "info-Tool" on a e.g. point-geometry).
What I have done so far:
-          I have a geometry-table in the MSSQL spatial database with point  geometries which works fine (displays in map, is editable etc..)
-          I have an attribute which contains an absolute path to a PDF-file on our server (The path is correct and works in Explorer).
-          I have defined an action of type "Open", given it a name, added the action [% "PDF File"%] referring to the attribute with the file path and added it to the action list.
When I open the Object Attribute Window and right click somewhere I can select my action BUT nothing happens, not even an error message... I'm clueless.
Using the Action Tool from the toolbar - same result, nothing happens, no error message.
Any ideas?
Thanks, best regards
Peter Schürch
Meier und Partner AG
Freiestrasse 26<x-apple-data-detectors://1/0>
8570 Weinfelden<x-apple-data-detectors://1/0>
www.meierpartner.ch<http://www.meierpartner.ch/>
T +41 71 626 5115<tel:+41%2071%20626%205115>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150914/b8120583/attachment.html>
