[Qgis-user] WG: qgis export to excel
Albin Blaschka
albin.blaschka at standortsanalyse.net
Mon Sep 14 02:55:30 PDT 2015
Hello!
There is also this fine plugin called "Quick Export" (The description:
"Quick Export adds a new toolbar in QGIS, with 4 actions to export any
vector layer to CSV, HTML, PDF and printer") which helps quite a lot
with questions like this - even if it not does exactly what you want.
Another Plugin which might help is "XYTools" ("Tools for managing
tabular data with x y columns. It can open spreadsheet files
(Libre/OpenOffice, Excel) as point layers and save attribute tables as
Excel file") - This one does what you want, as far as I can see.
HTH,
kind regards,
Albin
Am 14.09.2015 um 11:28 schrieb Peter Schürch:
> Unfortunately in newer versions of Excel (maybe Version > Office 2010?) you can't open DBF-Files anymore... Use CSV or do not use Excel.
> Regards, Peter
> -----Ursprüngliche Nachricht-----
> Von: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] Im Auftrag von Siki Zoltan
> Gesendet: Sonntag, 13. September 2015 09:13
> An: info at architekten.coop
> Cc: qgis-user at lists.osgeo.org
> Betreff: Re: [Qgis-user] qgis export to excel
> Dear Matthias,
> in the popup manu of the layer (right click on the layer name in Layers
> list) select Save as, select Coma separated value (CSV) or DBF file for the format. Both CSV and DBF can be opened by Excel (or Libre Office Calc).
> Regards,
> Zoltan
> On Sat, 12 Sep 2015, info at architekten.coop wrote:
>> dear qgis users
>> i use qgis as an architect, for roominformations of big building.
>> is there a possibility to export queryresultats to excel ?
>> thank you for any helb
>> matthias moser
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
| Dr.rer.nat. Albin Blaschka
| Etrichstrasse 26, A-5020 Salzburg
| * www.albinblaschka.info *
| * www.researchgate.net/profile/Albin_Blaschka *
| - It's hard to live in the mountains, hard but not hopeless!
