[Qgis-user] Export to vector file failed. Error: creation of data source failed (OGR error:Failed to open 'Convex Map Alma.dxf' for writing.)
Andreas Neumann
a.neumann at carto.net
Mon Sep 14 11:13:15 PDT 2015
Hi Joshua,
Did you know that there is a separate "DXF export" function that is
available in the "Project" menu? This is a much more powerful export
than through the Right click "Save AS" function.
However, if your data is broken it won't work either. But it may be
worth a try.
Andreas
On 14.09.2015 18:39, Joshua Friesen wrote:
> I am using QGIS 2.10.1- Pisa on a Mac. I’m a new user with little
> knowledge of the program. I added several vector layers from Google’s
> Mymaps (kmz. format) and then created a new vector layer on QGIS
> overtop. I then tried to export these layers (one at a time and also
> together) as a DXF autoCAD file, but there was an error with the
> export. When I right clicked on the layer and tried to ’save as’ a DXF
> file I received this message: "Export to vector file failed. Error:
> Alma.dxf' for writing.)”
> I have tried using other online converters to no avail. Some of the
> online converters say that there is no spatial data on the layers I
> try to upload as shapefiles. Can anyone give me any suggestions about
> what to do? Thanks very much for your help.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150914/db33d965/attachment.html>
