[Qgis-user] Saving qgs project file takes forever on VPN - no	problem with data
    magerlin
    MAP at ramboll.dk
    Tue Sep 15 02:19:39 PDT 2015
"... it is also not clear what would happen if you close the vpn connection
before the project is closed. "
I can tell that by bad experience: The last part of the qgs file is not
saved and the project is destroyed!
That is the main reason why I have Autosaver plugin installed!
Regards Morten
Currently using Qgis 2.10.1 (OSGeo4),
Windows 7, 64bit
View this message in context: http://osgeo-org.1560.x6.nabble.com/Saving-qgs-project-file-takes-forever-on-VPN-no-problem-with-data-tp5224216p5224241.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
