[Qgis-user] Saving qgs project file takes forever on VPN - no problem with data
DelazJ
delazj at gmail.com
Tue Sep 15 02:28:55 PDT 2015
Hi Morten,
Does Autosaver plugin save quickly the project file? Or is this process
also slow?
2015-09-15 11:19 GMT+02:00 magerlin <MAP at ramboll.dk>:
> "... it is also not clear what would happen if you close the vpn connection
> before the project is closed. "
> I can tell that by bad experience: The last part of the qgs file is not
> saved and the project is destroyed!
> That is the main reason why I have Autosaver plugin installed!
> Regards Morten
> Currently using Qgis 2.10.1 (OSGeo4),
> Windows 7, 64bit
> http://osgeo-org.1560.x6.nabble.com/Saving-qgs-project-file-takes-forever-on-VPN-no-problem-with-data-tp5224216p5224241.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150915/2bcb504f/attachment.html>
