[Qgis-user] to change the location of several points on a map
Andreas Neumann
a.neumann at carto.net
Wed Sep 16 02:01:07 PDT 2015
There are several methods to do this.
You could extract the x/y values (for points this is easy) in the field
calculator and change the coordinates with the new vectors and then
write that back into the geometry itself. Then create a WKT geometry
string (something like "POINT(coordx coordy)") and use geom_from_wkt in
the field calculator to write this back into the geometry.
Or alternatively export the thing in a CSV, do the calculation in the
spreadsheet and load the layer back.
Whatever you do: have a look at the field calculator - it is very powerful!
Hope this helps,
Andreas
On 16.09.2015 10:41, ralfwessels wrote:
> Hi Natalia,
> try the Plugin "Vector Bender".
> It does to vectors what georefencers does to raster.
> Good luck!
> ralf
> View this message in context: http://osgeo-org.1560.x6.nabble.com/to-change-the-location-of-several-points-on-a-map-tp5224359p5224422.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
