[Qgis-user] to change the location of several points on a map
    Schroeder Natalia
    natalias at mendoza-conicet.gob.ar
    Wed Sep 16 04:53:06 PDT 2015
Thank you very much Andreas and Ralf! I would explore your ideas.
Cheers
Natalia
El 16/09/2015 a las 06:01 a.m., Andreas Neumann escribió:
> There are several methods to do this.
> You could extract the x/y values (for points this is easy) in the
> field calculator and change the coordinates with the new vectors and
> then write that back into the geometry itself. Then create a WKT
> geometry string (something like "POINT(coordx coordy)") and use
> geom_from_wkt in the field calculator to write this back into the
> geometry.
> Or alternatively export the thing in a CSV, do the calculation in the
> spreadsheet and load the layer back.
> Whatever you do: have a look at the field calculator - it is very
> powerful!
> Hope this helps,
> Andreas
> On 16.09.2015 10:41, ralfwessels wrote:
>> Hi Natalia,
>> try the Plugin "Vector Bender".
>> It does to vectors what georefencers does to raster.
>> Good luck!
>> ralf
>> View this message in context:
>> http://osgeo-org.1560.x6.nabble.com/to-change-the-location-of-several-points-on-a-map-tp5224359p5224422.html
>> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
Natalia M. Schroeder
Laboratorio de Interacciones Ecológicas (LIE)
Instituto Argentino de Investigaciones de las Zonas Áridas (IADIZA), CONICET
CC 507, CP 5500, Mendoza, Argentina.
TE: +54-261-5244166
http://personal.mendoza-conicet.gob.ar/natalias/
