[Qgis-user] What's wrong with PRJ file for CRS 3857?
Goyo
goyodiaz at gmail.com
Wed Sep 16 13:41:47 PDT 2015
2015-09-16 22:00 GMT+02:00 Redoute <redoute at tortenboxer.de>:
> Are you saying that it is not possible to fully describe this projection
> as WKT without using a "PROJ4 extension" (or to reference auth ids that
> use a "PROJ4 extension")?
That's the question. I'd really like to know the answer in all its gory details.
> And this extension is that new/uncommon, so that it cannot be written
> into the primary prj file? Meaning that exchanging CRS 3857 shapefiles
> between different applications, e. g. from QGIS to CartoDB, will ever
> result in heavy projection errors?
There doesn't have to be errors as long as you can tell the target
program what the correct CRS is. I do not know if that's the case with
cartodb, though.
Goyo
