[Qgis-user] How to edit csv file
Paulo van Breugel
p.vanbreugel at gmail.com
Fri Sep 18 00:01:12 PDT 2015
Hi Jan,
Did you check out the GPS tools plugin for QGIS? Go to menu -> plugins
-> manage and install plugins and look for that name. That tool should
be able to handle GPX files.
Paulo
On 17-09-15 21:27, Bernd Vogelgesang wrote:
> Hi Jan,
> it's not possible to edit csv-files, cause they are opened as a
> read-only connection. (Hover with the mouse over the layer in the
> layer Panel, and it will show you the
> To be able to edit your data, you have to save them to another format
> (ESRI-shape, spatialite etc.)
> If you need the edited data as csv again, just export them to csv
> afterwards (Save as ...)
> No idea about iPhones
> Cheers
> Bernd
> Am 17.09.2015, 21:14 Uhr, schrieb Jan Becket <janbecket.net at gmail.com>:
>> Beginning user here - just migrated from Delorme X-Map Professionsl
>> on the Windows side to Q-GIS on a Mac. I figured out that I cannot
>> edit my GPX waypoint files in Q-GIS (which I did in X-Map) and so
>> have shifted them to csv format w/ GPS Babel. No problem, except that
>> I need to frequently update and synchronize with waypoints on my
>> iPhone. When I open the attribute file for the csv point layer, the
>> edit function is grayed out. How to make the layer / source file
>> editable within Q-GIS?
>> A related question - I am using Gaia GPS on the iPhone (w/ a Garmin
>> bluetooth GLO receiver). Is there a better iPhone app out there that
>> might communicate directly w/ Q-GIS and bypass the need to manually
>> update the csv layer?
>> Thanks!
>> Jan Becket
>> Honolulu
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
