[Qgis-user] automatically reload (csv) file
Dr. Marco Lechner
mlechner at bfs.de
Fri Sep 18 01:15:15 PDT 2015
Hi Nicola,
I guess this will only redraw the features in the mapcanvas, but not
necessarily read the datasource file, but I'm not sure about this.
Marco
Am 18.09.2015 um 10:02 schrieb Nicola Poles:
> To reload a CSV file you can press the Refresh button on the toolbar or
> press the "F5" key
> Nicola
> On Fri, Sep 18, 2015 at 9:16 AM, Dr. Marco Lechner <mlechner at bfs.de
> <mailto:mlechner at bfs.de>> wrote:
> Hi,
> how (often) does QGIS read features from a file (like csv or shape -
> differences?)? I realize I do not really know how the datasource - qgis-
> communication goes.
> Imaine you have a csv or shape file that is loaded into QGIS but is
> automatically replaced from time to time (or lets say externally
> edited). Using a database- instead of file-based approach is better for
> sure, but still it is not clear when / how often (on which events) QGIS
> requests features from the datasources.
> As an idea in mind I see, the nice Sync-Plugin
> (https://plugins.qgis.org/plugins/SyncQGISWithDir/) can monitor folders
> and notify the user if a new layer is available in a folder (well it
> does not take care of a changed layer (new timestamp of file, but adding
> this functionality should not be such a big thing). The user could also
> be notified when a layers file changed.
> But I'm not sure what was the best way to implement the (re)loading of
> an already loaded layer. Do I have to drop the layer and reload it
> (including keeping the style) or is there a more efficient way?
> Marco
> Dr. Marco Lechner
> Bundesamt fuer Strahlenschutz / Federal Office for Radiation Protection
> SW2.1 Koordination Notfallschutzsysteme / Coordination Emergency Systems
> Rosastrasse 9 | D-79098 Freiburg | Germany
> mlechner at bfs.de <mailto:mlechner at bfs.de> | +49 (0)3018 333 6724
> <tel:%2B49%20%280%293018%20333%206724> | www.bfs.de <http://www.bfs.de>
> Hinweis zu Anhängen die auf .p7m/.p7c/.p7s oder .asc/.asc.sig enden:
> Die .p7?- und .asc-Dateien sind ungefährliche Signaturdateien (digitale
> Unterschriften).
> In E-Mail-Clients mit S/MIME Konfiguration (.p7?) oder PGP-Erweiterung
> (.asc) dienen sie zur:
> - - Überprüfung des Absenders
> - - Überprüfung einer evtl. Veränderung des Inhalts während der
> Übermittlung über das Internet
> Die Signaturdateien können ebenso dazu verwendet werden dem Absender
> dieser Signatur eine E-Mail mit verschlüsseltem Inhalt zu senden.
> In E-Mail-Clients ohne S/MIME Konfiguration oder PGP-Erweiterung
> erscheinen die Dateien als Anhang und können ignoriert werden.
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
Type: application/pgp-keys
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150918/b6f7f3a4/attachment.key>
Type: application/pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150918/b6f7f3a4/attachment.bin>
