[Qgis-user] automatically reload (csv) file
Nicola Poles
nicola.poles at gmail.com
Fri Sep 18 01:22:40 PDT 2015
It reads the datasource and updates the layer accordingly, including the
coordinates and all the attributes.
On Fri, Sep 18, 2015 at 10:15 AM, Dr. Marco Lechner <mlechner at bfs.de> wrote:
> Hi Nicola,
> I guess this will only redraw the features in the mapcanvas, but not
> necessarily read the datasource file, but I'm not sure about this.
> Marco
> Am 18.09.2015 um 10:02 schrieb Nicola Poles:
> > To reload a CSV file you can press the Refresh button on the toolbar or
> > press the "F5" key
> > Nicola
> > On Fri, Sep 18, 2015 at 9:16 AM, Dr. Marco Lechner <mlechner at bfs.de
> > <mailto:mlechner at bfs.de>> wrote:
> > Hi,
> > how (often) does QGIS read features from a file (like csv or shape -
> > differences?)? I realize I do not really know how the datasource -
> qgis-
> > communication goes.
> > Imaine you have a csv or shape file that is loaded into QGIS but is
> > automatically replaced from time to time (or lets say externally
> > edited). Using a database- instead of file-based approach is better
> for
> > sure, but still it is not clear when / how often (on which events)
> QGIS
> > requests features from the datasources.
> > As an idea in mind I see, the nice Sync-Plugin
> > (https://plugins.qgis.org/plugins/SyncQGISWithDir/) can monitor
> folders
> > and notify the user if a new layer is available in a folder (well it
> > does not take care of a changed layer (new timestamp of file, but
> adding
> > this functionality should not be such a big thing). The user could
> also
> > be notified when a layers file changed.
> > But I'm not sure what was the best way to implement the (re)loading
> of
> > an already loaded layer. Do I have to drop the layer and reload it
> > (including keeping the style) or is there a more efficient way?
> > Marco
> > Dr. Marco Lechner
> > Bundesamt fuer Strahlenschutz / Federal Office for Radiation
> Protection
> > SW2.1 Koordination Notfallschutzsysteme / Coordination Emergency
> Systems
> > Rosastrasse 9 | D-79098 Freiburg | Germany
> > mlechner at bfs.de <mailto:mlechner at bfs.de> | +49 (0)3018 333 6724
> > <tel:%2B49%20%280%293018%20333%206724> | www.bfs.de <
> http://www.bfs.de>
> > Hinweis zu Anhängen die auf .p7m/.p7c/.p7s oder .asc/.asc.sig enden:
> > Die .p7?- und .asc-Dateien sind ungefährliche Signaturdateien
> (digitale
> > Unterschriften).
> > In E-Mail-Clients mit S/MIME Konfiguration (.p7?) oder
> PGP-Erweiterung
> > (.asc) dienen sie zur:
> > - - Überprüfung des Absenders
> > - - Überprüfung einer evtl. Veränderung des Inhalts während der
> > Übermittlung über das Internet
> > Die Signaturdateien können ebenso dazu verwendet werden dem Absender
> > dieser Signatur eine E-Mail mit verschlüsseltem Inhalt zu senden.
> > In E-Mail-Clients ohne S/MIME Konfiguration oder PGP-Erweiterung
> > erscheinen die Dateien als Anhang und können ignoriert werden.
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150918/fa546d7d/attachment.html>
