[Qgis-user] automatically reload (csv) file
Andreas Neumann
a.neumann at carto.net
Fri Sep 18 02:57:09 PDT 2015
Hi Delazj,
Yes - I was assuming that people would use the "Add delimited text layer
tool". Sorry - I forgot to mention that. It is more flexible and easier
to use than the "Add vector layer" dialogue.
About CSV, joins and updates: have you checked the cache vs. uncached
option for your joins?
Andreas
On 18.09.2015 11:47, DelazJ wrote:
> Hi,
> Andreas, unless you add the csv file with "Add delimited text layer"
> tool, I'm afraid there's not a "watch file" option available.
> I just add a csv file to a qgis project with "add a vector layer"
> tool. I open the same csv in a text editor and change some values.
> While reopening the csv file attribute table in QGIS, values were
> already uptodate. I've done nothing special. So I'm not sure if QGIS
> requiers a particular action to sync data.
> But what seems buggy is that even if the csv file attribue table is
> updated in QGIS, if this csv was joined to a shapefile, the changes
> won't be applied in the shapefile's attribute table. Can someone confirm?
> I can't get changes with the "Refresh" button.
> Tested with qgis ltr 2.8.3
> 2015-09-18 10:38 GMT+02:00 Andreas Neumann <a.neumann at carto.net
> <mailto:a.neumann at carto.net>>:
> Hi Marco,
> If you have the "watch file" option of your CSV file active it
> will reread data when file content changes and when your redraw
> your map (either through navigation or redraw button).
> I guess you could also write a small Python script if you want to
> automatically trigger an update at a given interval. Maybe there
> is already a plugin available - I did not look.
> Andreas
> On 18.09.2015 10:15, Dr. Marco Lechner wrote:
>> Hi Nicola,
>> I guess this will only redraw the features in the mapcanvas, but not
>> necessarily read the datasource file, but I'm not sure about this.
>> Marco
>> Am 18.09.2015 um 10:02 schrieb Nicola Poles:
>>> To reload a CSV file you can press the Refresh button on the toolbar or
>>> press the "F5" key
>>> Nicola
>>> On Fri, Sep 18, 2015 at 9:16 AM, Dr. Marco Lechner <mlechner at bfs.de <mailto:mlechner at bfs.de>
>>> <mailto:mlechner at bfs.de> <mailto:mlechner at bfs.de>> wrote:
>>> Hi,
>>> how (often) does QGIS read features from a file (like csv or shape -
>>> differences?)? I realize I do not really know how the datasource - qgis-
>>> communication goes.
>>> Imaine you have a csv or shape file that is loaded into QGIS but is
>>> automatically replaced from time to time (or lets say externally
>>> edited). Using a database- instead of file-based approach is better for
>>> sure, but still it is not clear when / how often (on which events) QGIS
>>> requests features from the datasources.
>>> As an idea in mind I see, the nice Sync-Plugin
>>> (https://plugins.qgis.org/plugins/SyncQGISWithDir/) can monitor folders
>>> and notify the user if a new layer is available in a folder (well it
>>> does not take care of a changed layer (new timestamp of file, but adding
>>> this functionality should not be such a big thing). The user could also
>>> be notified when a layers file changed.
>>> But I'm not sure what was the best way to implement the (re)loading of
>>> an already loaded layer. Do I have to drop the layer and reload it
>>> (including keeping the style) or is there a more efficient way?
>>> Marco
>>> Dr. Marco Lechner
>>> Bundesamt fuer Strahlenschutz / Federal Office for Radiation Protection
>>> SW2.1 Koordination Notfallschutzsysteme / Coordination Emergency Systems
>>> Rosastrasse 9 | D-79098 Freiburg | Germany
>>> mlechner at bfs.de <mailto:mlechner at bfs.de> <mailto:mlechner at bfs.de> <mailto:mlechner at bfs.de> |+49 (0)3018 333 6724 <tel:%2B49%20%280%293018%20333%206724>
>>> <tel:%2B49%20%280%293018%20333%206724> |www.bfs.de <http://www.bfs.de> <http://www.bfs.de> <http://www.bfs.de>
>>> Hinweis zu Anhängen die auf .p7m/.p7c/.p7s oder .asc/.asc.sig enden:
>>> Die .p7?- und .asc-Dateien sind ungefährliche Signaturdateien (digitale
>>> Unterschriften).
>>> In E-Mail-Clients mit S/MIME Konfiguration (.p7?) oder PGP-Erweiterung
>>> (.asc) dienen sie zur:
>>> - - Überprüfung des Absenders
>>> - - Überprüfung einer evtl. Veränderung des Inhalts während der
>>> Übermittlung über das Internet
>>> Die Signaturdateien können ebenso dazu verwendet werden dem Absender
>>> dieser Signatur eine E-Mail mit verschlüsseltem Inhalt zu senden.
>>> In E-Mail-Clients ohne S/MIME Konfiguration oder PGP-Erweiterung
>>> erscheinen die Dateien als Anhang und können ignoriert werden.
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org> <mailto:Qgis-user at lists.osgeo.org>
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> _______________________________________________ Qgis-user
>>> mailing list Qgis-user at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150918/a1712160/attachment.html>
