[Qgis-user] automatically reload (csv) file
DelazJ
delazj at gmail.com
Fri Sep 18 02:47:02 PDT 2015
Andreas, unless you add the csv file with "Add delimited text layer" tool,
I'm afraid there's not a "watch file" option available.
I just add a csv file to a qgis project with "add a vector layer" tool. I
open the same csv in a text editor and change some values. While reopening
the csv file attribute table in QGIS, values were already uptodate. I've
done nothing special. So I'm not sure if QGIS requiers a particular action
to sync data.
But what seems buggy is that even if the csv file attribue table is updated
in QGIS, if this csv was joined to a shapefile, the changes won't be
applied in the shapefile's attribute table. Can someone confirm?
I can't get changes with the "Refresh" button.
Tested with qgis ltr 2.8.3
2015-09-18 10:38 GMT+02:00 Andreas Neumann <a.neumann at carto.net>:
> Hi Marco,
> If you have the "watch file" option of your CSV file active it will reread
> data when file content changes and when your redraw your map (either
> through navigation or redraw button).
> I guess you could also write a small Python script if you want to
> automatically trigger an update at a given interval. Maybe there is already
> a plugin available - I did not look.
> Andreas
> On 18.09.2015 10:15, Dr. Marco Lechner wrote:
> Hi Nicola,
> I guess this will only redraw the features in the mapcanvas, but not
> necessarily read the datasource file, but I'm not sure about this.
> Marco
> Am 18.09.2015 um 10:02 schrieb Nicola Poles:
> To reload a CSV file you can press the Refresh button on the toolbar or
> press the "F5" key
> Nicola
> On Fri, Sep 18, 2015 at 9:16 AM, Dr. Marco Lechner <mlechner at bfs.de<mailto:mlechner at bfs.de> <mlechner at bfs.de>> wrote:
> Hi,
> how (often) does QGIS read features from a file (like csv or shape -
> differences?)? I realize I do not really know how the datasource - qgis-
> communication goes.
> Imaine you have a csv or shape file that is loaded into QGIS but is
> automatically replaced from time to time (or lets say externally
> edited). Using a database- instead of file-based approach is better for
> sure, but still it is not clear when / how often (on which events) QGIS
> requests features from the datasources.
> As an idea in mind I see, the nice Sync-Plugin
> (https://plugins.qgis.org/plugins/SyncQGISWithDir/) can monitor folders
> and notify the user if a new layer is available in a folder (well it
> does not take care of a changed layer (new timestamp of file, but adding
> this functionality should not be such a big thing). The user could also
> be notified when a layers file changed.
> But I'm not sure what was the best way to implement the (re)loading of
> an already loaded layer. Do I have to drop the layer and reload it
> (including keeping the style) or is there a more efficient way?
> Marco
> Dr. Marco Lechner
> Bundesamt fuer Strahlenschutz / Federal Office for Radiation Protection
> SW2.1 Koordination Notfallschutzsysteme / Coordination Emergency Systems
> Rosastrasse 9 | D-79098 Freiburg | Germany
> mlechner at bfs.de <mailto:mlechner at bfs.de> <mlechner at bfs.de> | +49 (0)3018 333 6724
> <tel:%2B49%20%280%293018%20333%206724> | www.bfs.de <http://www.bfs.de> <http://www.bfs.de>
> Hinweis zu Anhängen die auf .p7m/.p7c/.p7s oder .asc/.asc.sig enden:
> Die .p7?- und .asc-Dateien sind ungefährliche Signaturdateien (digitale
> Unterschriften).
> In E-Mail-Clients mit S/MIME Konfiguration (.p7?) oder PGP-Erweiterung
> (.asc) dienen sie zur:
> - - Überprüfung des Absenders
> - - Überprüfung einer evtl. Veränderung des Inhalts während der
> Übermittlung über das Internet
> Die Signaturdateien können ebenso dazu verwendet werden dem Absender
> dieser Signatur eine E-Mail mit verschlüsseltem Inhalt zu senden.
> In E-Mail-Clients ohne S/MIME Konfiguration oder PGP-Erweiterung
> erscheinen die Dateien als Anhang und können ignoriert werden.
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org> <Qgis-user at lists.osgeo.org>
> Qgis-user mailing listQgis-user at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150918/f4ebd7e1/attachment.html>
