[Qgis-user] SVG borders with data defined override in Postgis layer
didier peeters
dpeeter1 at ulb.ac.be
Fri Sep 18 05:36:45 PDT 2015
I can refine my description :
the problem occurs on the border width only, the border color works fine.
Still, no one has ever met this problem ?
Didier
> Le 17 sept. 2015 à 22:37, didier peeters <dpeeter1 at ulb.ac.be> a écrit :
> Hello,
> I have a problem with the border parameter of SVG markers in QGis 2.10 (on Mac OS 10.10.5); I’m using PostGIS layers and the SVG markers properties are determined by the DB, i.e. the svg itself, the color, the rotation, with data define override. I also want to define the border color and width the same way but it doesn’t work, nothing happens. If I deactivate the overriding everything is correct.
> For the color I use a varchar type (same as for the color of the svg itself) and for the width a numeric (also tried real, double precision, …) .
> I haven’t found any bug report about this. Any idea ?
> Didier
> Qgis-user mailing list
