[Qgis-user] SVG borders with data defined override in Postgis layer
Andreas Neumann a.neumann at carto.net
Fri Sep 18 05:42:08 PDT 2015
Hi Didier,
Did you prepare your SVG file accordingly?
You need something like the following in your SVG file wherever you want
to dynamically replace properties:
|<rect fill="param(fill) #ff0000" stroke="param(outline) #00ff00"
stroke-width="param(stroke-width) 10" width="100" height="100"> See also
http://blog.sourcepole.ch/2011/06/30/svg-symbols-in-qgis-with-modifiable-colors/
Can you share your SVG file so I can have a look if it is properly prepared?
Andreas
On 18.09.2015 14:36, didier peeters wrote:
> I can refine my description :
> the problem occurs on the border width only, the border color works fine.
> Still, no one has ever met this problem ?
> Didier
>> Le 17 sept. 2015 à 22:37, didier peeters <dpeeter1 at ulb.ac.be> a écrit :
>> Hello,
>> I have a problem with the border parameter of SVG markers in QGis 2.10 (on Mac OS 10.10.5); I’m using PostGIS layers and the SVG markers properties are determined by the DB, i.e. the svg itself, the color, the rotation, with data define override.  I also want to define the border color and width the same way but it doesn’t work, nothing happens.  If I deactivate the overriding everything is correct.
>> For the color I use a varchar type (same as for the color of the svg itself) and for the width a numeric (also tried real, double precision, …) .
>> I haven’t found any bug report about this.  Any idea ?
>> Didier
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150918/11061af2/attachment.html>
