[Qgis-user] SVG borders with data defined override in Postgis layer
didier peeters
dpeeter1 at ulb.ac.be
Fri Sep 18 05:57:53 PDT 2015
Hi Andreas,
yes, I can define a border width ‘manually’ in the styling of the layer, but I cannot override this with a value from Postgis.
I will send you a svg.
Didier
See also http://blog.sourcepole.ch/2011/06/30/svg-symbols-in-qgis-with-modifiable-colors/ <http://blog.sourcepole.ch/2011/06/30/svg-symbols-in-qgis-with-modifiable-colors/>
> Le 18 sept. 2015 à 14:42, Andreas Neumann <a.neumann at carto.net <mailto:a.neumann at carto.net>> a écrit :
> Hi Didier,
> Did you prepare your SVG file accordingly?
> You need something like the following in your SVG file wherever you want to dynamically replace properties:
> <rect fill="param(fill) #ff0000" stroke="param(outline) #00ff00" stroke-width="param(stroke-width) 10" width="100" height="100">
> Can you share your SVG file so I can have a look if it is properly prepared?
> Andreas
> On 18.09.2015 14:36, didier peeters wrote:
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> Qgis-user mailing list
>> I can refine my description :
>> the problem occurs on the border width only, the border color works fine.
>>> Still, no one has ever met this problem ?
>>> Didier
>>> Le 17 sept. 2015 à 22:37, didier peeters <dpeeter1 at ulb.ac.be> <mailto:dpeeter1 at ulb.ac.be> a écrit :
>>> I have a problem with the border parameter of SVG markers in QGis 2.10 (on Mac OS 10.10.5); I’m using PostGIS layers and the SVG markers properties are determined by the DB, i.e. the svg itself, the color, the rotation, with data define override. I also want to define the border color and width the same way but it doesn’t work, nothing happens. If I deactivate the overriding everything is correct.
>> http://lists.osgeo.org/mailman/listinfo/qgis-user <http://lists.osgeo.org/mailman/listinfo/qgis-user>
>>> Hello,
>>> I haven’t found any bug report about this. Any idea ?
>>>> For the color I use a varchar type (same as for the color of the svg itself) and for the width a numeric (also tried real, double precision, …) .
>>>> Didier
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150918/bf51e7c4/attachment.html>
