[Qgis-user] qgis server - line symbology
Markus Weidenbach
landconsult at freenet.de
Sat Sep 19 07:34:44 PDT 2015
Hi Mark,
I have exactly the same problem.
I installed the QGIS Server 2.2 (valmiera) on my remote Linux/Debian
server and as long as I was feeding it with Projectfiles made with QGIS
Valmiera 2.2 all worked fine, but since I upgraded my Desktop QGIS to
2.8.2, I have the same problem with the vector and polygon outlines,
which all appear black.
So, obviously the older QGIS server cannot handle the symbology settings
of the newer xml project files produced with QGIS 2.8.
Did you, or anybody else on the list, know a workaround other than
updating the older QGIS server (which could be a tricky work ....)?
Markus *
*Am 15.04.2015 00:24, schrieb Mark Seibel:
> I'm using Qgis Desktop 2.6, and when I move the files to the qgis web
> server, the symbology for lines as well as polygon outlines do not get
> rendered any other way than a black line. Points and polygon fills
> (solid and hatching) symbolize correctly in qgis server.
> I have done this before and had it working, but perhaps under a
> different version. The underlying vector data is shapefiles.
> Any suggestions?
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150919/c2415f6d/attachment.html>
