[Qgis-user] Error Python beginning Qgis 2.10 (english) - Error Python inicio Qgis 2.10 (español)
Matthias Kuhn matthias at opengis.ch
Sun Sep 20 08:38:43 PDT 2015
F.Y.I. in the current development version - and the upcoming version
2.12 - the issue is be resolved and arbitrary user names/directory paths
supported.
Best,
Matthias
On 09/20/2015 03:55 PM, Anita Graser wrote:
> The issue is caused by the special character in your user name as far
> as I can tell. Can you change it?
> Best wishes,
> Anita
> On Sun, Sep 20, 2015 at 2:43 PM, Adrián Gayo <adrian.gayo at yahoo.es
> <mailto:adrian.gayo at yahoo.es>> wrote:
>     Hi!!
>     For time I drag this error in the updates of Qgis and it prevents
>     me from being able to use with all his potential, for example,
>     many plugin they do not work due to these errors. It wanted to
>     known how it might update Python, but I do not know how.
>     Next I show you the error that goes out on having initiated Qgis:
>     No se pudo cargar el complemento processing debido a un error al
>     llamar a su método classFactory()
>     Traceback (most recent call last):   File
>     "C:/PROGRA~1/QGISPI~1/apps/qgis/./python\qgis\utils.py", line 219,
>     in startPlugin     plugins[packageName] =
>     package.classFactory(iface)   File
>     "C:/Users/Adri�n/.qgis2/python/plugins\processing\__init__.py",
>     line 37, in classFactory     from processing.ProcessingPlugin
>     import ProcessingPlugin   File
>     "C:/PROGRA~1/QGISPI~1/apps/qgis/./python\qgis\utils.py", line 478,
>     in _import     mod = _builtin_import(name, globals, locals,
>     fromlist, level)   File
>     "C:/Users/Adri�n/.qgis2/python/plugins\processing\ProcessingPlugin.py",
>     line 47, in     if cmd_folder not in sys.path:   File
>     "C:/PROGRA~1/QGISPI~1/apps/qgis/./python\qgis\utils.py", line 55,
>     in showWarning     "warning:%s\ntraceback:%s" % (
>     warnings.formatwarning(message, category, filename, lineno), stk),
>     UnicodeDecodeError: 'ascii' codec can't decode byte 0xe1 in
>     position 21: ordinal not in range(128)
>     Versión de Python:
>     2.7.5 (default, May 15 2013, 22:44:16) [MSC v.1500 64 bit (AMD64)]
>     Versión de QGIS:
>     2.10.1-Pisa Pisa, d20c5b7
>     Thank you in advance.
>     Mensaje en Español:
>     Buenos días,
>     Desde hace tiempo arrastro este error en las actualizaciones de
>     Qgis y me impide poder utilizarlo con todo su potencial, por
>     ejemplo, muchos plugin no me funcionan debido a estos errores.
>     Quería saber cómo podría actualizar Python.
>     A continuación os muestro el error que sale al iniciar Qgis:
>     Versión de Python:
>     Versión de QGIS:
>     Gracias.
>     _______________________________________________
>     Qgis-user mailing list
>     Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150920/301dc0b8/attachment.html>
