[Qgis-user] Error Python beginning Qgis 2.10 (english) - Error Python inicio Qgis 2.10 (español)
Anita Graser
anitagraser at gmx.at
Sun Sep 20 06:55:16 PDT 2015
The issue is caused by the special character in your user name as far as I
can tell. Can you change it?
Best wishes,
Anita
On Sun, Sep 20, 2015 at 2:43 PM, Adrián Gayo <adrian.gayo at yahoo.es> wrote:
> Hi!!
> For time I drag this error in the updates of Qgis and it prevents me from
> being able to use with all his potential, for example, many plugin they do
> not work due to these errors. It wanted to known how it might update
> Python, but I do not know how.
> Next I show you the error that goes out on having initiated Qgis:
> No se pudo cargar el complemento processing debido a un error al llamar a
> su método classFactory()
> Traceback (most recent call last):
> File "C:/PROGRA~1/QGISPI~1/apps/qgis/./python\qgis\utils.py", line 219, in startPlugin
> plugins[packageName] = package.classFactory(iface)
> File "C:/Users/Adri�n/.qgis2/python/plugins\processing\__init__.py", line 37, in classFactory
> from processing.ProcessingPlugin import ProcessingPlugin
> File "C:/PROGRA~1/QGISPI~1/apps/qgis/./python\qgis\utils.py", line 478, in _import
> mod = _builtin_import(name, globals, locals, fromlist, level)
> File "C:/Users/Adri�n/.qgis2/python/plugins\processing\ProcessingPlugin.py", line 47, in
> if cmd_folder not in sys.path:
> File "C:/PROGRA~1/QGISPI~1/apps/qgis/./python\qgis\utils.py", line 55, in showWarning
> "warning:%s\ntraceback:%s" % ( warnings.formatwarning(message, category, filename, lineno), stk),
> UnicodeDecodeError: 'ascii' codec can't decode byte 0xe1 in position 21: ordinal not in range(128)
> Versión de Python:
> 2.7.5 (default, May 15 2013, 22:44:16) [MSC v.1500 64 bit (AMD64)]
> Versión de QGIS:
> 2.10.1-Pisa Pisa, d20c5b7
> Thank you in advance.
> Mensaje en Español:
> Buenos días,
> Desde hace tiempo arrastro este error en las actualizaciones de Qgis y me
> impide poder utilizarlo con todo su potencial, por ejemplo, muchos plugin
> no me funcionan debido a estos errores. Quería saber cómo podría actualizar
> Python.
> A continuación os muestro el error que sale al iniciar Qgis:
> Versión de Python:
> Versión de QGIS:
> Gracias.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150920/befba81b/attachment.html>
