[Qgis-user] Concatenate address fields with NULLS
Phil (The Geek) Wyatt phil at wyatt-family.com
Sun Sep 20 17:28:36 PDT 2015
Many thanks for all the suggestions - I will give them a try
Cheers - Phil
[mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Phil (The Geek)
Wyatt
Sent: Sunday, 20 September 2015 5:54 PM
To: Qgis-user at lists.osgeo.org
Subject: [Qgis-user] Concatenate address fields with NULLS
Hi Folks,
I am working with LIST Address Points data from
http://listdata.thelist.tas.gov.au/opendata/ (Specifically Clarence
Municipality) and I need to concatenate into one field the full address of
each location. I am struggling to figure out how to do it when there are
fields for unit numbers, building names, numbers to and from etc. Many of
the fields are also NULL so clearly I want those fields disregarded.
Can someone give me a quick heads up on how to NOT add the data from a field
that has NULL?
Chances are I will be doing this regularly so I am keen to document the
required expressions for others to use as well.
Cheers - Phil
Volunteer Mapper -  <http://www.redcross.org.au/volunteering.aspx> Red Cross
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150921/008a8366/attachment.html>
