[Qgis-user] Concatenate address fields with NULLS
    Andreas Neumann
    a.neumann at carto.net
    Mon Sep 21 04:19:34 PDT 2015
Hi Bernhard,
This is provider dependent. In PostgreSQL you will have to double quotes
around the field names if they contain upper case letters or special
characters not valid in SQL object names. QGIS stays on the "safe" side
and will always add double quotes around the fields, even if it isn't
strictly required.
Andreas
On 21.09.2015 13:11, Bernd Vogelgesang wrote:
> Am 21.09.2015, 08:39 Uhr, schrieb Andreas Neumann <a.neumann at carto.net>:
>     ... if you use capital letters in field names (which is discourage
>     anyway).
> Hi Andreas,
> could you elaborate a little on why not to use capital letters for
> field names? Recently I started using capital letters for fields,
> cause for me, any expressions and codes becomes much better readable.
> (Which also reminds me, that a lot of processing functions change
> field names to upper case or lower case or leave them as is, totally
> unconsistenly.)
> Cheers
> Bernd
>     On 20.09.2015 12:59, Matthias Kuhn wrote:
>>     Hi Phil,
>>     In addition to COALESCE I'd like to promote the use of the
>>     function *CONCAT()* which treats NULL values as empty strings (it
>>     was changed recently, it's probably since 2.10) what makes it
>>     very handy.
>>     Example:
>>     NULL || "hello" -> NULL
>>     vs.
>>     CONCAT( NULL , "hello") -> "hello
>>     vs.
>>     COALESCE( NULL, "" ) || "hello" -> "hello"
>>     Cheers,
>>     Matthias
>>     On 09/20/2015 09:54 AM, Phil (The Geek) Wyatt wrote:
>>>     Hi Folks,
>>>     I am working with LIST Address Points data from
>>>     http://listdata.thelist.tas.gov.au/opendata/ (Specifically
>>>     Clarence Municipality) and I need to concatenate into one field
>>>     the full address of each location. I am struggling to figure out
>>>     how to do it when there are fields for unit numbers, building
>>>     names, numbers to and from etc. Many of the fields are also NULL
>>>     so clearly I want those fields disregarded.
>>>     Can someone give me a quick heads up on how to NOT add the data
>>>     from a field that has NULL?
>>>     Chances are I will be doing this regularly so I am keen to
>>>     document the required expressions for others to use as well.
>>>     Cheers - Phil
>>>     Volunteer Mapper - Red Cross
>>>     <http://www.redcross.org.au/volunteering.aspx>
>>>     _______________________________________________
>>>     Qgis-user mailing list
>>>     Qgis-user at lists.osgeo.org
>>>     http://lists.osgeo.org/mailman/listinfo/qgis-user
> Bernd Vogelgesang
> Siedlerstraße 2
> 91083 Baiersdorf/Igelsdorf
> Tel: 09133-825374
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150921/c808fe1b/attachment.html>
