[Qgis-user] Concatenate address fields with NULLS
Bernd Vogelgesang bernd.vogelgesang at gmx.de
Mon Sep 21 04:11:57 PDT 2015
Am 21.09.2015, 08:39 Uhr, schrieb Andreas Neumann <a.neumann at carto.net>:
> ... if you use capital letters in field names (which is discourage
> anyway).
Hi Andreas,
could you elaborate a little on why not to use capital letters for field
names? Recently I started using capital letters for fields, cause for me,
any expressions and codes becomes much better readable.
(Which also reminds me, that a lot of processing functions change field
names to upper case or lower case or leave them as is, totally
unconsistenly.)
Cheers
Bernd
> On 20.09.2015 12:59, Matthias Kuhn wrote:
>> Hi Phil,
>> In addition to COALESCE I'd like to promote the use of the function
>> CONCAT() which treats NULL values as empty strings >>(it was changed
>> recently, it's probably since 2.10) what makes it very handy.
>> Example:
>> NULL || "hello" -> NULL
>> vs.
>> CONCAT( NULL , "hello") -> "hello
>> vs.
>> COALESCE( NULL, "" ) || "hello" -> "hello"
>> Cheers,
>> Matthias
>> On 09/20/2015 09:54 AM, Phil (The Geek) Wyatt wrote:
>>> Hi Folks,
>>> I am working with LIST Address Points data from
>>> http://listdata.thelist.tas.gov.au/>>>opendata/ (Specifically Clarence
>>> Municipality) and I need to concatenate into one >>>field the full
>>> address of each location. I am struggling to figure out how to do it
>>> >>>when there are fields for unit numbers, building names, numbers to
>>> and from etc. >>>Many of the fields are also NULL so clearly I want
>>> those fields disregarded.
>>> Can someone give me a quick heads up on how to NOT add the data from a
>>> field that >>>has NULL?
>>> Chances are I will be doing this regularly so I am keen to document
>>> the required >>>expressions for others to use as well.
>>> Cheers - Phil
>>> Volunteer Mapper - Red Cross
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
Bernd Vogelgesang
Siedlerstraße 2
91083 Baiersdorf/Igelsdorf
Tel: 09133-825374
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150921/6faa0a45/attachment.html>
