[Qgis-user] Concatenate address fields with NULLS
Andreas Neumann
a.neumann at carto.net
Mon Sep 21 01:28:35 PDT 2015
Hi Matthias and Jürgen,
Thanks for your clarifications. Now it makes more sense and I agree that
the Concat version is easier to use.
Andreas
On 21.09.2015 10:26, Matthias Kuhn wrote:
> To clarify with a more meaningful example, the following two
> expressions are equal
> * CONCAT( name, ', ', country )
> * COALESCE( name, '' ) || ', ' || COALESCE( country, '' )
> Example:
> Given features with the attributes:
> * Feature 1:
> country: 'Japan'
> * Feature 2:
> country: NULL
> The result is for both methods:
> * Feature1: 'Tokyo, Japan'
> * Feature2: ', Atlantis'
> PS: thanks for the hint with the quotes, I was to quick on the send button
> Best regards,
> Matthias
> On 09/21/2015 08:39 AM, Andreas Neumann wrote:
>> Hi,
>> So how is concat(NULL,fieldname) any better than
>> COALESCE(fieldname,''). To me it is the same complexity and not
>> really an improvement. But maybe I don't get it. The only slight
>> advantage would be that "concat" may be a more familiar term than
>> coalesce. But if you come from a database background you already know
>> COALESCE. Any serious GIS professional needs to know databases.
>> Another small thing:
>> Do not mix up double quotes (") and single quotes ('). Whenever you
>> use a string, do use single quotes, when you use an attribute either
>> use no quotes or double quotes for some providers if you use capital
>> letters in field names (which is discourage anyway).
>> Andreas
>> On 20.09.2015 12:59, Matthias Kuhn wrote:
>>> Hi Phil,
>>> In addition to COALESCE I'd like to promote the use of the function
>>> *CONCAT()* which treats NULL values as empty strings (it was changed
>>> recently, it's probably since 2.10) what makes it very handy.
>>> Example:
>>> NULL || "hello" -> NULL
>>> vs.
>>> CONCAT( NULL , "hello") -> "hello
>>> vs.
>>> COALESCE( NULL, "" ) || "hello" -> "hello"
>>> Cheers,
>>> Matthias
>>> On 09/20/2015 09:54 AM, Phil (The Geek) Wyatt wrote:
>>>> Hi Folks,
>>>> I am working with LIST Address Points data from
>>>> http://listdata.thelist.tas.gov.au/opendata/ (Specifically Clarence
>>>> Municipality) and I need to concatenate into one field the full
>>>> address of each location. I am struggling to figure out how to do
>>>> it when there are fields for unit numbers, building names, numbers
>>>> to and from etc. Many of the fields are also NULL so clearly I want
>>>> those fields disregarded.
>>>> Can someone give me a quick heads up on how to NOT add the data
>>>> from a field that has NULL?
>>>> Chances are I will be doing this regularly so I am keen to document
>>>> the required expressions for others to use as well.
>>>> Cheers - Phil
>>>> Volunteer Mapper - Red Cross
>>>> <http://www.redcross.org.au/volunteering.aspx>
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150921/aab9fe3d/attachment.html>
