Hi all, I tried using the dissolve tool from the QGIS geoprocessing tools and all features get dissolved together, resulting in only one feature, regardless of the dissolve field. I tried with several datasets. Do you have the same problem or is it only me ? I've used this tool in the past, and it worked ok. Thanks for your help ! Julie.
