[Qgis-user] hughe file project file size with qgis 2.10
Nyall Dawson
nyall.dawson at gmail.com
Wed Sep 30 14:00:55 PDT 2015
On 23 September 2015 at 01:03, lars lingner <gislars+list at gmail.com> wrote:
> Hi Andreas,
> On 22.09.2015 09:09, Andreas Neumann wrote:
>> Hi Lars,
>> Wow - this must be a big bug. I also have quite large QGIS projects
>> (50-100 layers) - but they are never beyond 1 MB in filesize.
> Just out of curiosity: Do you have styles applied to your layers? Is
> this the file size Qgis is creating or are you stripping out manually?
> I'd love to have files with 1 MB.
>> Did you report this as a bug? Maybe Nyall could have a look at it, as he
>> did the layer effects stuff.
> No, not yet. I want to be sure it is really a bug/issue with Qgis, since
> I couldn't find any other reports.
Try with a revision after 0587a59b - should be fixed now. Now the
effect element will only be written if it's had the effect settings
altered.
You'll need to open & resave your project using a version later than
this for the change to apply.
Regards,
Nyall
> Thanks so far. Maybe other user can comment on this topic.
> Best wishes
> Lars
> Qgis-user mailing list
