[Qgis-user] RES: Trouble with select by location between point and line layer
João Carneiro
jhcarneiro at axaeng.com
Fri Sep 25 12:53:18 PDT 2015
Updating the information below
I have checked that select by location only selects the points that are
snapped to a vertice of a sg_line, but not snapped to segments. Is this
working as expected, or do we have a bug here?
Att.,
João Carneiro
De: João Carneiro [mailto:jhcarneiro at axaeng.com]
Enviada em: sexta-feira, 25 de setembro de 2015 14:40
Para: 'qgis-user at lists.osgeo.org'
Assunto: Trouble with select by location between point and line layer
Hello,
Has anyone had the following problems?
I am trying to detect topological problems in my data between two classes
called sg_point and sg_line. Our topological rule is that sg_point MUST be
snapped to sg_line.
I imagine that the best way to do this is by using Select By Location and
select all points that intersect the line. Unfortunately this does not work,
and neither does trying the opposite selection. Trying to select all the
points that dont intersect the line gives me 100% of the points even if
there were some points that were correctly snapped to the line beforehand.
I have not managed to select only the points that dont intersect the line
or only the points that do intersect the line.
What am I doing wrong?
Thanks for any help.
Best regards,
João Carneiro
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20150925/d685559c/attachment.html>
