[Qgis-user] RES: Trouble with select by location between point and line layer
Håvard Tveite
havard.tveite at nmbu.no
Sun Sep 27 13:35:21 PDT 2015
A tolerance value would probably be needed in the general
case.
Have you tested with horizontal or vertical lines?
Håvard Tveite
On 25. sep. 2015 21:53, João Carneiro wrote:
> Updating the information below –
> I have checked that select by location only selects the points that are
> snapped to a vertice of a sg_line, but not snapped to segments. Is this
> working as expected, or do we have a bug here?
> Att.,
> João Carneiro
> *De:*João Carneiro [mailto:jhcarneiro at axaeng.com]
> *Enviada em:* sexta-feira, 25 de setembro de 2015 14:40
> *Para:* 'qgis-user at lists.osgeo.org'
> *Assunto:* Trouble with select by location between point and line layer
> Hello,
> Has anyone had the following problems?
> I am trying to detect topological problems in my data between two
> classes called sg_point and sg_line. Our topological rule is that
> sg_point MUST be snapped to sg_line.
> I imagine that the best way to do this is by using “Select By Location”
> and select all points that intersect the line. Unfortunately this does
> not work, and neither does trying the opposite selection. Trying to
> select all the points that don’t intersect the line gives me 100% of the
> points even if there were some points that were correctly snapped to the
> line beforehand.
> I have not managed to select only the points that don’t intersect the
> line or only the points that do intersect the line.
> What am I doing wrong?
> Thanks for any help.
> Best regards,
> João Carneiro
> Qgis-user mailing list
