[Qgis-user] qgis WPS-Client input
Jonas Pedersen
dollarklavs at gmail.com
Fri Apr 1 01:26:25 PDT 2016
Hi List and especially those that know anything about the WPS-Client plugin,
I’m creating a WPS that can calculate a line of sight from a start point (with a custom height) to an end point.
The service itself works as I can input the start and end point as GML in an URL as in the below URL and get a return result.
http://172.17.5.171/cgi-bin/zoo_loader.cgi?Service=WPS&Request=Execute&Identifier=ExtractlineofsightGML&DataInputs=startpoint=%3Cgml:Point%3E%3Cgml:coordinates%3E711330,6197923%3C/gml:coordinates%3E%3C/gml:Point%3E;endpoint=%3Cgml:Point%3E%3Cgml:coordinates%3E711370,6197970%3C/gml:coordinates%3E%3C/gml:Point%3E;height=20&Version=1.0.0& <http://172.17.5.171/cgi-bin/zoo_loader.cgi?Service=WPS&Request=Execute&Identifier=ExtractlineofsightGML&DataInputs=startpoint=%3Cgml:Point%3E%3Cgml:coordinates%3E711330,6197923%3C/gml:coordinates%3E%3C/gml:Point%3E;endpoint=%3Cgml:Point%3E%3Cgml:coordinates%3E711370,6197970%3C/gml:coordinates%3E%3C/gml:Point%3E;height=20&Version=1.0.0&>
(Doesn’t work externally yet)
But when opening the service in the qgis WPS-Client plugin I can’t figure out what input’s will make the service work there.
The WPS service is created using the zoo-project framework and the input data is defined as:
<ComplexData>
<Default>
mimeType = text/xml
encoding = UTF-8
schema = http://schemas.opengis.net/gml/3.1.0/base/feature.xsd <http://schemas.opengis.net/gml/3.1.0/base/feature.xsd>
</Default>
</ComplexData>
When inputting a vector point in the WPS client I get an error that states “Invalid GML representation…”
See screenshot from my gis.stackexchange question for the entire error.
http://gis.stackexchange.com/q/187473/52250 <http://gis.stackexchange.com/q/187473/52250>
How does the WPS-Client interpret GML?
//Jonas
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160401/48543946/attachment.html>
