[Qgis-user] Faulty Plugin
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Fri Apr 1 17:39:33 PDT 2016
Not sure,
Start by turning off all plugins. Update to the last version of Qgis. What version of window are you on and what installer are you using? That will help other trouble shoot.
Nicolas
On Apr 1, 2016 20:31, "Ayanda Sigwela [via OSGeo.org] " <ml-node+s1560n5259272h93 at n6.nabble.com> wrote:
Hello, I forgot to indicate that also “gpsimporter plugnin” crashed the Qgis startup. Please assist From: Ayanda Sigwela [mailto: [hidden email] ] Sent: 02 April 2016 02:03 AM To: 'Nicolas Cadieux' < [hidden email] >; ' [hidden email] ' < [hidden email] > Subject: [Qgis-user] Faulty Plugin Greetings, I am a new Qgis user. I downloaded version 2.14.0. Upon uploading a shapefile, the software crashed. When I re-opened it, it came up with this screen. Apparently Plugin MetaSearch crashed the system. The instruction is that I should report it for problem resolution. Below is the picture of what came up. Please advise what should I do. Regards Ayanda _______________________________________________
Qgis-user mailing list
[hidden email]
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/Re-Faulty-Plugin-tp5259272.html
To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
To unsubscribe from Quantum GIS - User, click here .
NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Re-Faulty-Plugin-tp5259272p5259274.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160401/0ac07b81/attachment.html>
