[Qgis-user] Print composer from 2.10 not working in 2.12
Uwe Fischer gisfisch at t-online.de
Mon Apr 4 10:36:59 PDT 2016
Hello List,
I have a QGS document with a lot of themes and a custom legend that was
finished in QGIS 2.10. The maps had to be delivered in PDF format. Now there
is a minor change request in one map. I have updated to 2.12 in the
meantime. After opening the QGS, making the change, and saving it, I was not
able to produce a proper PDF output any more. A PDF document is written, but
is has only 2 KB and shows up empty.
In other projects, PDF output from 2.12 works very well.
I’d hate to reproduce the map setup and composition in 2.12 from scratch for
that minor change. I am not sure if it makes sense to go back to 2.10 for
that?? Or is it possible that 2.14 is able to produce output from the older
version?
Thanks for ideas and suggestions,
Uwe
Ingenieurbüro Fischer
Esbecker Str. 8
31036 Eime
Tel.: 05182/8325
Mobil: 0172/8876934
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160404/7fe957db/attachment.html>
